2009 Chevy Camaro Question about fog lights
CITYK
Electrical problem
2009 Chevy Camaro 4 cyl Four Wheel Drive Manual
Hi, I got a 2010 all new Camaro from chevy and I bought LS one which doesn't contains fog lights and I was wondering I can add fog lights on my car? Should I change the whole bumper or drill'em?
How much would it cost in general? any idea would help me. thanks.
Mar 22, 2009 at 5:21 PM
BRIAN 1
  • 1,030 POSTS
before you do anything I would call the dealer and see if you can add an OEM system.you might also want to check if its pre wired,it might have the plugs behind the front bumper and look in the fuse block if it will accept a fog lamp relay.also check the RPO code list,for fog lights it will be T3U.the RPO list is in the glove box.post back with any other questions.
Mar 23, 2009 at 9:37 AM
