2004 Chevy Camaro window
27,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHARGER#3
Driver window will not work. I have taken off the door panel everything is plugged up. Can't see anything wrong. Not sure how to take the window motor out or what to do.
Jul 2, 2008 at 2:41 AM
MUSTANG87
  • 261 POSTS
check first if your getting power to the motor it might be the switch hopefully,if not then u need a motor.its kinda messy to changethe w motor.you gotta remove the window regulator all out.what i do is remove the 3 or 4 rivets that hold the regulator with motor.i grind the rivets to level then pop m out with a small screw driver same with motor ,has 3 rivets holding it to regulator.to install i just buy new small nuts n bolts to put it back together.u gotta remove the motor out side because its got rivets and its hard to remove them when in.if your not sure what u doing take it to a shop because it is pretty trickie and frustrating .
Jul 3, 2008 at 8:30 AM
