check first if your getting power to the motor it might be the switch hopefully,if not then u need a motor.its kinda messy to changethe w motor.you gotta remove the window regulator all out.what i do is remove the 3 or 4 rivets that hold the regulator with motor.i grind the rivets to level then pop m out with a small screw driver same with motor ,has 3 rivets holding it to regulator.to install i just buy new small nuts n bolts to put it back together.u gotta remove the motor out side because its got rivets and its hard to remove them when in.if your not sure what u doing take it to a shop because it is pretty trickie and frustrating .
Jul 3, 2008 at 8:30 AM
