2002 Chevy Camaro what is it?
2002 CHEVROLET CAMARO
SWEISEND89
Drive Train Axles Bearings problem
2002 Chevy Camaro 6 cyl Two Wheel Drive Automatic
i hit a curb in my camaro and bent up the driverside rear end. i need to replace the piece behind the plate of the axle shaft. its kind of goldish in color and it bolts on the outside of the axle housing. i need to know what that piece is called so what is it?
and im also starting to think i might need to replace the axle housing. what is a reasonable price for the housing to be replaced if i buy the parts?
Apr 14, 2010 at 12:37 PM
HMAC300
  • 48,601 POSTS
the gold piece may be your calper/parkin g brake mount. you would be better off going to a junkyard for the axle and contacting them for a price..
Apr 19, 2010 at 6:59 AM
