2002 Chevy Camaro valvetrain noise
93,500 MILES • V8 • 2WD • MANUAL
DIETER88
There is a very loud tapping noise coming from the front of the left valve cover. It began as a very loud chirping sound but now has settled into a constant, very loud tapping noise that changes with the rpm of the engine. The engine, however, performs as new, though I doubt it will for long as it seems doomed unless I fix the problem. Please give me an idea of what to expect.
Feb 1, 2008 at 10:37 PM
MERLIN2021
  • 17,250 POSTS
Can be either a weak valve spring, or bad hydraulic lifter, or worn cam lobe...A weak spring can be detected by a vacuum gauge, needle will bounce...
Feb 1, 2008 at 11:11 PM
