2002 Chevy Camaro Turn signal
2002 CHEVROLET CAMARO
57,000 MILES • 6 CYL • 2WD • AUTOMATIC
DADAMTRENT
My turn signal for the left works automatically. The rear left turn signal works automatically. The rear right turn signal works manually when flipping it on and off. The right front turn signal light comes on but does not signal. The bulb is good and has been checked but even when manually operating the signal the right front signal will not blink. Do you have any suggestions on what is causing this to occur? Thank you.
May 8, 2009 at 1:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect flasher relay. If flasher is OK then suspect faulty multi-function (turn signal) switch.
Thanks for using 2CarPros.com!
May 8, 2009 at 1:59 PM
