i have a semi rough idle when completly warmed up i was wondering which sensors would be included in a rough idle I.E MAP ,? throttle positioning?
Sep 26, 2008 at 5:18 PM
✓Experienced Mechanic
Plugs and wires okay? if so-start checking the idle air control valve/throttle position sensor/MAF
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
