2002 Chevy Camaro replacing power window motor on passenger
35,000 MILES • 6 CYL • 2WD • AUTOMATIC
STILLBILL
Can you please explain to me how to access the power window motor on my camaro? I have removed the door paneling and power switch, but to get at the motor I have to remove the metal frame wher the motor is attached? I am not a quitter, and will continue this quest, but I need some help. Thank you very much, James Cook
Dec 11, 2007 at 11:12 PM
ARTMANG
  • 61 POSTS
just spot the screws on the window motor and u will need to drill a hole on the sheet metal over the screws to remove them.big enough hole to remove the screw out.u will se a small dent or point where the scres r located and try to find them with a flash light i know its hard to see in there but find them .thats the only way .dam chevy makes it hard to fix those .just like explorers too.dont remove the metal frame its way to hard and most likely u cant .ive doen this work and its a bit triky but when u get it u get it .good to know ur not a quiter so get the bull by the horns man lol.
Dec 14, 2007 at 2:22 PM
