2002 Chevy Camaro Problem getting into gear
2002 CHEVROLET CAMARO
41,000 MILES • V8 • 2WD • MANUAL
FGECK
I have a 2002 Camaro with a 6ap manual transmission. Started it today and could not get it into gear. turn it off then it can go into gear. The clutch doe snot feel as firm. I think it maybe low on fluid for the hydralic system. Where to you check it, how where is it etc..
Thanks
It was the fluid level and I found it. Why woudl it be low, only a lead? id not see any on the ground but car 6+ years old now
Dec 6, 2008 at 7:24 AM
DOCFIXIT
  • 18,828 POSTS
The slave cylinder inside trans bellhousing would not see minor leak keep eye on it and when it is clutch replace.
Dec 7, 2008 at 6:28 AM
