2002 Chevy Camaro poor mileage, lean running
BLACKNIGHT
Engine Performance problem
2002 Chevy Camaro V8 Two Wheel Drive Manual 91k miles
I have a scanner with live data and the fuel trims are a little lean part throttle and wot and the spark plugs confirm a lean running motor. Also about a 4 mpg drop and lack of power. I have tried another mass air sensor, tps, fuel filter, tested fuel pressure=good, and different fuel additives to with the gas. Both sides are lean with the driverside showing leaner. 0 codes.
Mar 14, 2010 at 9:16 AM
HMAC300
  • 48,601 POSTS
has this engine been modified and the computer not matched to richen the mix? LIke a different cam or headers. and check for a vacuum leak. Maybe the leak i to big and the compter can'tcompensate for it.
Mar 18, 2010 at 3:28 AM
