2002 Chevy Camaro overheating
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
KJARAMILLO
my '02 camaro has a small leak on the rear of the motor i cant pinpoint whether it is the head gasket or the intake manifold gasket. For about a week it was running fine even with the leak, but as of late it buried the guage way past 260 degrees causing it not to accelerate at all and pretty much lose power and smoke severely. One of my friends suggested that my thermostat may have stuck closed. What are your thoughts on the matter
May 8, 2009 at 1:51 PM
  • 75,988 POSTS
Investigate thoroughly could be a freeze plug that's leaking
May 8, 2009 at 1:53 PM
KJARAMILLO
First and foremost sir thanks for your service in vietnam. I am an active duty seabee. What is a freeze plug?
May 8, 2009 at 1:57 PM
  • 75,988 POSTS
You're welcome I love them river boats you guys got back then helps a lot in the mekong delta with the seals Sir the freeze plug are right along the engine block-How's the heater hoses? You can pressure test it to find where its leaking
https://images.2carpros.com/forum/automotive_pictures/12900_250pxCorrodedCorePlug_1.jpg
Freeze plug is another name for core plug or expansion plug, and is commonly referred to as a "frost plug." They are a subset of the plugs on a car engine cylinder block or cylinder head. The traditional plug is a thin, domed, disc of metal which fits into a machined hole in the casting and is secured by striking or pressing the center to expand the disc. A true freeze plug is an expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant does not have enough antifreeze protection it can freeze and crack the engine block. The freeze plugs (there are usually several) are supposed to pop out under such conditions to relieve the pressure on the block. Most of the plugs to be found on an engine are actually to plug the holes where sand cores have been held. The sand cores are used in the casting process to form internal cavities in the engine block or cylinder head, for cooling water for example, and so should really be referred to as core plugs. Freeze plugs can often be a source of troublesome leaks as a result of internal cooling system corrosion. Ease of replacement depends on accessibility. In many cases the plug area will be difficult to reach and using a mallet to perform maintenance or replacement will be nearly impossible without special facilities. Expanding rubber plugs are available as replacements when access is a problem.
May 8, 2009 at 2:40 PM
