2002 Chevy Camaro No start problem
132,000 MILES • 6 CYL • 2WD • MANUAL
GEOSPK7
I have a camaro that will not start. It has good spark and is in top shape mechanically. The fuel pressure regulator is new. The fuel filter is new. All of the injectors have been replaced. I have checked the pump pressure and relays all good. The gas has been drained and replaced. The car turns over but will not startup unless you spray starting fluid into to the intake. It then will start and run for a few seconds and then die. Any help will be great!
Jun 17, 2010 at 1:44 PM
  • 75,988 POSTS
Fuel injectors might not be snchronizing or not getting power up due to blown injectors fuses.
Jun 17, 2010 at 1:51 PM
