2002 Chevy Camaro labor price
65,000 MILES • V8 • 2WD • MANUAL
RMEASSICK
labor time to replace a clutch in a 2002 camaro with a 6-speed
Feb 20, 2009 at 12:30 AM
TEAG
  • 158 POSTS
Its impossible to say. It all depends on the knowledge of the mechanic and with how familiar they are with your vehicle. Also some shops have minimum hours charge. On top of that....price per hour varies from shop to shop. The need to special order parts could also cause delay time wise. Your best bet is to call the shop you intend to have the work done at and ask for an estimate. If its not what you think is a descent price....call around and compare. Thatll give you an idea of the going rate where you live. Good luck :)
Feb 22, 2009 at 8:25 PM
