2002 Chevy Camaro Fuel pump replacement needed?
NZ CHEVY FAN
Electrical problem
2002 Chevy Camaro V8 Two Wheel Drive Automatic
My 2002 camaro has a couple of issues that i think are related.
It sometimes will wind over but not start - maybe 3-4 time will then run fine.
if i change the fuel pump relay it start imediatly.
I am thinking that the fuel pump pick up maybe restriced causing the pump to draw too much current burning out the relay, or the pump is just faulty causing this issue.
This has happend a number of times.
I would like to be sure that i am getting the right parts and doing the righ thing to fix the issue as I have to import all my camaro parts to New Zealand.
Can you assist with this issue and do i have to remove the tank to access or replace the fuel pump?
Aug 20, 2010 at 3:19 PM
  • 110,248 POSTS
Have you checked the connections where the relay plugs in? Also, when it doesn't start, have you checked to see if there is fuel pump pressure to the engine?
Aug 20, 2010 at 4:07 PM
NZ CHEVY FAN
There is no fuel pressure when this fault occurs.
The fun of intermittant fualt finding.
there was nothing visible at the relay connections - but i will check them in more detail
Aug 21, 2010 at 11:22 AM
  • 110,248 POSTS
It sounds like a bad relay.
Aug 21, 2010 at 2:43 PM
NZ CHEVY FAN
It is a brand new GM relay and the issure still came back within about 3 weeks and it is still intermittant
Aug 22, 2010 at 3:52 PM
  • 110,248 POSTS
If the relay is good, then check to make sure the connectors are good.
Aug 22, 2010 at 4:56 PM
