2002 Chevy Camaro 2002 Camaro 3.8 v6
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
DILUTED3069
I started my car today and it started spitting and spuddering. When I go above 2000 rpms it started doing this also. I took it to a shop and hooked it up to a computer, it said that my cylinder #5 is misfiring. i thought maybe it was the sparkplugs, but then they started telling me it was the IGN Coil, Wireset, or sparkplugs. any suggestions before i start waisting money?
May 4, 2008 at 12:35 PM
PRODRIGU
  • 26 POSTS
Couldn't be the coil because if I am not mistaken, you have coil packs therefore you would have two cylinders misfiring since the coil packs drive two cylinders, check the plug wires, you should have the platinum plugs which are good for 100,000 miles but check the plug also and check for the color, is it black, wet, white or what ever that will tell you something. You may also have a bad injector or leaking injector.
May 18, 2008 at 4:07 AM
