1986 Chevy Camaro Sputters when accelerated and doesnt star
JCOPPER1192
  • 1986 CHEVROLET CAMARO
  • V8
  • 38,500 MILES
Every morning I drive to school, when I go to start the car it will take anywhere form 3-8 turn of the ignition to start, sometimes it even helps to give it a little gas. Im not sure if it is the fuel injectors. I have been putting fuel injector cleaner in for the last 2 fill ups. Also about 5 out of 7 days a week, I will pull out of the drive way and the car will sputter for about 3 minutes before it will actually accelerate smoothly. And finally, this hasn't happened before, but has been for the last couple days, I will stop at a red light and the car will stall out.
Here are some issues with the car: I has sat for 3 years without being ran, but only has 38000 miles.
thank you dor any help! -John
Tuesday, October 6th, 2009 AT 11:53 AM
LOUT5369
  • 217 POSTS
If you have a carburator, You're choke isn't working, if you have fuel injection, you have either a bad Idle air control motor, or fuel pressure regulator.
Thursday, October 8th, 2009 AT 6:39 AM
RAYMACKIN123
  • 6 POSTS
My 98 camaro had a sputtering problem. When I would turn it on it would sputter and rev up and down for a while. Sometimes it wouldnt stop.
I replaced the spark plugs and it ran fine for 2 months. It started doing it again and replaced the ignition coils as well as a tube which bust and made engine overheat. After the second fix I havent had a problem at all. Its been a couple months and runs fine.
So it could be :
Ignition Coils, Spark Plugs or engine overheating. Take it to a mechanic and have them look it over
Tuesday, November 3rd, 2009 AT 6:51 PM
