2002 Chevy Camaro
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIAN123
i have had my car for about three weeks now. when i either come to a stop or am about to take off my engine hesitates and then dies out. i have already changed the mass air flow sensor 2 weeks ago and the check engine light is still reading that the mass airflow sensor is bad. some one told me it might be bad fuel injectors that are throwing the sensor off but i have no clue.
Jan 24, 2009 at 2:02 PM
RHALL77
  • 3,361 POSTS
are you checking the code your self? can your scanner read a data stream? try disconnecting it and test driving it.
Jan 27, 2009 at 10:17 AM
BRIAN123
i took it to an auto part store to have the codes checked. and it said the mass air flow was bad so i changed it . then about a week later the light came on again so i had the codes checked again and it said it was the mass airflow again and the o2 sensor.
Jan 27, 2009 at 12:40 PM
RHALL77
  • 3,361 POSTS
check and see if there is any vaccum leaks and also make sure your breather tubes are hooked up on your engine. whats was the o2 sensor code you recieved
Jan 29, 2009 at 5:09 AM
