2001 Chevy Camaro Hydraulic Clutch
2001 CHEVROLET CAMARO
70,000 MILES • 6 CYL • 2WD • MANUAL
BUDLITE
My clutch pedal on my 2001 camaro wont return like it should. I shift into first and if I dont shift right to second, then I cant shift at all and the pedal stays in. If I dont use my foot to pop the clutch pedal out all the way, I cant shift either. I cant find anyway to adjust the pedal free travel. I am not to experienced with hydraulic clutches so any help would be useful.
Thanks
May 16, 2008 at 9:09 AM
MASTERTECHTIM
  • 4,750 POSTS
this usually means there is air in the system. have you bled the slave cylinder yet? try that
May 16, 2008 at 9:12 AM
BUDLITE
thanks for the advice!
May 16, 2008 at 9:18 AM
