2001 Chevy Camaro Hissing noise
126,000 MILES • 6 CYL • 2WD • MANUAL
CLAYTON LEMERT
I have a 2001 Chevy Camaro, 3.8L V6, 5-speed transmission. The car is making what sounds like a hissing noise, but it is only noticeable in third gear. The shop I took it to tells me there is a bad bearing in the transmission, and that I need a whole new or rebuilt transmission, which is very expensive. Is there any other way to fix this problem other than installing a new transmission? Any advice would be appreciated - thanks.
Oct 6, 2009 at 9:18 AM
LOUT5369
  • 217 POSTS
Sorry,You don't have a choice,there is no other way to fix it,you should have had it checked when it first started making noise,it could have been corrected with a fluid change. Sorry,Lou
Oct 7, 2009 at 11:47 PM
BARAN220
  • 17 POSTS
I don't know if anyone suggested this but find a good, I will call it "junk yard" for use of a better term. They will most likely have a decent 5 speed for you. I would not suggest this with an automatic. There are some good "yards" across the Country that have good, quality, salvaged parts.
Nov 8, 2009 at 6:47 AM
REDNEKWIZARD
  • 30 POSTS
Depending onwhere your at you can find a good pick a part yard that lets you pull the parts you need and they can be much cheaper than a regular salvage yard.
Nov 9, 2009 at 6:16 AM
