2001 Chevy Camaro
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
DMAC004
My 2001 camaro over heated while i was driving i was hearing a knocking noise so i pulled over and checked the radiator to see if there was water and it was empty.. i waited a while and put water in it but it does not want to fill. whats causing it not to fill.
Jan 8, 2010 at 4:59 PM
ERNEST CLARK
  • 1,730 POSTS
When you say it doesn't want to fill, do you mean you pour coolant in but it never fills to the top?
If so, and you're not seeing any coolant flowing on the ground, then it's flowing inside of your engine, and either into the oil, or into the cylinder and then into the exhaust. (Blown head gasket)
Pull your dip stick. If the oil is white (like a milk shake), then there's your coolant. If not, then it's going into the exhaust.
To find exactly where your head gasket blew, pull the spark plugs one at a time and check them for wetness. You may have one or both head gaskets blown.
Jan 9, 2010 at 12:35 AM
