2001 camaro convertible 6 cyl. 55000 miles/shake/shudder
M STEWART
At about 48 mph, there is a violent shaking problem.
You can still feel it at lower speeds also, but not as bad.
I have had two different set of tires and rim combinations put on the car.
I had the struts and shocks replaced. I had stabilzer bars put on the car. I took this car to 4 different car care places no one can give me any answers. Everyone keeps blaming tires.
Jan 14, 2007 at 3:56 AM
EHLIN
  • 30 POSTS
I have a 1995 3.4 Camaro 126k mi and I have the same problem, please get back to me if you find a solution!
thebetancourt@gmail.com
Aug 7, 2008 at 5:43 PM
TEAG
  • 158 POSTS
Changing the rotor hub and bearings should fix it. Ive just dealt with a problem like this and the rotor was slightly bent and the bearings were worn. The bearings are very cheap....about 6 bucks....so worth replacing while your in that far. Hope it helps.
Oct 17, 2008 at 6:48 AM
