2000 Chevy Camaro wnont start when hot
2000 CHEVROLET CAMARO
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
CEBO305
car wont crank when hot after 15min-100hr in stores or at home . After it coools off, then it will crank.
Mar 4, 2010 at 1:47 PM
Next time it happens don't wait for nothing,do below immediately to determine whether it's fuel or spark problem.Get back with some result.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 4, 2010 at 5:18 PM
