THE SPEAKER SOUND VIBRATES ON BASS. WHAT IS THE PROCEDURE FOR REMOVING & REPLACING THE SPEAKER IN THE RIGHT HAND DOOR.
Jan 31, 2009 at 10:00 AM
EUGENE123
✓Experienced Mechanic
take yor door panel off, take the bolts out of the speaker, unhook the wires from the speaker, remeber which wire was hooked to the positve and which wire was hooked to the negative then install the new speaker hook the new wires up by soldering the wires with a soldering gun to the postive and negative on the new speaker put the bolts back in the speaker and put you door panel back on :)
