2000 Chevy Camaro Rear noise
150,000 MILES • V8 • 2WD • AUTOMATIC
DICK BRITTON
I am not sure if i have a rear tire noise problem or possible axle bearing problem. their is a low humming noise i think coming from the left dirver side rear axle. this seems to get louder when i get up to speed and i can hear it when i come to a stop.
The tires are fairly new. this is a z28
Feb 23, 2008 at 6:41 AM
DAN P
  • 9 POSTS
seen some pinion bearings go out ,can pin point the area of noise with stethoscope , [can use a screw driver]check area by ft pinion bearing, sides buy case bearings, and out by axle bearings.
Mar 10, 2008 at 3:37 PM
