2000 Chevy Camaro power surges, no pick up
59,985 MILES • 6 CYL • FWD • AUTOMATIC
TRIPPE
I got some bad gassoline not long ago. Put heat in it, ran ok for awhile. Check Engine light comes on and flashes. It has a new battery, I replaced the plugs/wires. Had better gas put in it, along with oil change and fuel injection fluid added. It still feels like it is pulling back, runs like a rag, no pick up. When sitting still, it vibrates.
Mar 13, 2009 at 9:58 AM
TEAG
  • 158 POSTS
If your check engine light comes on at all.....you need to have it scanned and thatll tell you what the problem is. Theres so many things that could cause your problem. You could try cleaning the o2 sensor but Id really have it scanned before wasting any time on anything. If you dont have or know anyone with an obd2 scanner you could take it to your local auto parts store. Most will run a scan for free. Try that and see what comes up and if you have problems fixing the problem....repost here and I'll get back to ya. Good luck :)
Mar 14, 2009 at 11:44 AM
