2000 Chevy Camaro leaking water
2000 CHEVROLET CAMARO
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIRDIRTYDEEDS
water is coming into the car from under the dash on the pasgner side and the window will fog up from the heat from the motor like all the cooant is laking on that side of the car  are there hooses that run under the dash ?
Mar 25, 2009 at 11:33 PM
MERLIN2021
  • 17,250 POSTS
If the "water" comming in is sticky and sweet smelling, it's coolant, and the leak is from the heater core, to stop the leak, you can replace the core, or temporary fix is join the two heater hoses with a tube and eliminate the core, of course you will not have any heat!
Mar 26, 2009 at 12:56 AM
