2000 Chevy Camaro Engine will not start
35,000 MILES • V8 • 2WD • AUTOMATIC
JCOLONE
  • 7 POSTS
For about 1 year or so the car had an intermittent problem not starting. I had it looked at and the dealer, they said it my be a dead spot in the starter but they were not sure. Well now the car will not start at all, prior to this the alarm system had an intermittent problem. We checked the starter and it seems to be ok, replaced battery and replaced Body Control Module, still will not start. Not sure why. Please give me any help. Thanks John
May 8, 2008 at 8:09 AM
MERLIN2021
  • 17,250 POSTS
When you say it has trouble what kind? Clicking? or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
And as for the BCM, was it programed?
Aug 17, 2019 at 9:48 AM
