2000 Chevy Camaro clutch
114,000 MILES • V8 • 2WD • MANUAL
DRAGONTAU
my clutch will partially disengage when cold but when it is hot it will go straight to the floor and stay there. i have replaced the master cylinder, hose and the slave cylinder. before i put my starter on, i could feel the pressure plate disengaging when the pedal was pushed, what can cause this?
Oct 2, 2010 at 1:31 PM
HMAC300
  • 48,601 POSTS
the release arm could have bent or the clutch could have gone bad if it did it's probably a coincidence. but check to see if you have air in the clutch hydraulic system as well.
Oct 22, 2010 at 12:29 PM
