1999 Chevy Camaro stalls when leaving stop sign with ac on
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKE MURLEY
the car run fine down the highway but when you stop and then try to leave a stop sign it will stall and die with the air conditioner on. With it off it hesitates but does not die.
Jun 25, 2010 at 5:53 AM
02REDCAMARO
  • 65 POSTS
Hi, just had a similar problem with a 2002 V6 Camaro,
if your plugs and wires are fine, replace the coils. I had a similar problem, especially when engine was warm and under load (with air cond or many people in car). Trouble codes won't tell you if coils are bad, and testing them with an ohm meter won't do you any good. They are cheap on eBay. I replaced all 3 on my car for $60 and a half hour of labor.
Jul 9, 2010 at 12:38 PM
