1999 Chevy Camaro Service Engine Soon
13,500 MILES • 6 CYL • 2WD • AUTOMATIC
ANGBILL10
A rebuilt engine was replaced with mileage of 80,000 from used car dealer.
Problem wtih Service Engine light had diagonistic test and replaced throttle plate. Lasted about 6 months now same problem again. Hard time starting and stalling out. Diagnostic test again and had battery replaced - was told by Chevy Dealer battery was not giving enough power to reset codes. Lasted about 1 week - same problem again had time starting and Service Engine Light Soon.
May 3, 2010 at 3:18 PM
HMAC300
  • 48,601 POSTS
have the codes checked again to see what they are. Then check the cranks and cam sensors for resistance. Alot of times they don't give codes but aren't any good causing an intermittent or no start condition. Also check the fuel filter as it can cause some stalling running problems as well as the map sensor. Then clean the throttle plate with choke cleaner on both sides
May 5, 2010 at 10:56 AM
