1999 Chevy Camaro Sensors?
JDRUTHER
Engine Mechanical problem
1999 Chevy Camaro 6 cyl Two Wheel Drive 112,00 miles
How many Oxygen sensors does a 1999 camaro have & which one is the one that reduces the engine power/ Or which one is known to be the 1st to go out & need replaced/ Thanx~ :)
May 23, 2010 at 1:41 PM
HMAC300
  • 48,601 POSTS
there may be 4 depending on how many converters you have. if you have 2 converters then there are 4 02 sensors. there are pre and post. THE pre ones are teh ones that will effect engine running the most.
May 24, 2010 at 10:44 AM
