1999 Chevy Camaro Radiator fans
51,000 MILES • V8 • 2WD • MANUAL
JHARRIMAN
Is it possible for a temp sensor to not kick on the fans yet still operate the temp gauge? I have tested the fan motors, relays, and wring between them. I have a two wire temp sensor.
Feb 25, 2010 at 3:24 AM
CARADIODOC
  • 34,413 POSTS
The computer and gauge use separate sensors.
caradiodoc
Feb 25, 2010 at 3:45 AM
JHARRIMAN
Where is the other located? I have found the one on the Left forward head, is that the one that turns the fans on through the computer?
Feb 25, 2010 at 4:44 AM
CARADIODOC
  • 34,413 POSTS
During this time period, GM and Chrysler products, which I'm very familiar with, did things the same way. On the Chryslers, the gauge sending unit has only a single wire. The engine computer's sensor has two wires.
Unplug the sensor you replaced while the engine is running. If the Check Engine light turns on, that's the computer's sensor. If the gauge drops to "cold", it's for the gauge. If both things happen, then indeed the gauge would appear to be getting its information from the engine computer, possibly by way of the body computer.
Again, on Chryslers with electric fans, unplugging the computer's sensor will trigger the computer to turn on the radiator fan and put the ignition system into base timing mode. It does that because it knows it can't believe the sensor information and it will not know if the engine is overheating. Running the fan is a precaution. It will turn the fan off when the sensor is plugged back in. Im not sure if GMs turn the fan on, but it will turn the Check Engine light on.
caradiodoc
Feb 25, 2010 at 4:45 PM
