1999 Chevy Camaro power windows, radio randomly turn on and
83,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAWGDAWG91
Ever since I bought this car I have had this problem. The radio and power windows would randomly turn off and randomly trun back on. Now, the speedometer and RPM stopped working too. What is going on?
Jan 24, 2009 at 7:25 AM
MASTERTECHTIM
  • 4,750 POSTS
try wiggling the ignition switch when they cut off or try shutting off car and restarting and see if they start working. if they do replace the ignition switch
Jan 24, 2009 at 7:29 AM
KEVIN12881
  • 336 POSTS
mastertechtim, could it not be either the keyed ignition, or the electric one on the dash? that is what went out on my 95 trans am. I do believe it to be either one of the two
Jan 24, 2009 at 7:32 AM
MASTERTECHTIM
  • 4,750 POSTS
the electrical switch is usually the one that fails. the key turns a ignition cylinder which switches the electrical ignition switch
Jan 24, 2009 at 7:51 AM
KEVIN12881
  • 336 POSTS
ok, thats what i though, not a true mech and always thought that the keyed one was the switch and the one on the colomn was the electric switch.... the back screw is so fun to take out!!!
Jan 24, 2009 at 8:01 AM
