1999 Chevy Camaro poor engine preformance
RICH7412
  • 1999 CHEVROLET CAMARO
  • V8
  • 77,000 MILES
I have a 1999 camaro Z28. It hesitates on a hard, ( or even a moderate pull). I changed the fuel filter with a new one with no improvement. I was wondering if anyone knows if this is a common problem with these cars, and what ya think the solution might be.
any thoughts are welcome. Thanks
Sunday, March 14th, 2010 AT 6:01 PM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Sunday, March 14th, 2010 AT 6:10 PM
