1999 Chevy Camaro need to know
58,600 MILES • 6 CYL • 2WD • AUTOMATIC
ANITAW45
Hi I have a 1999 chev camaro and there is oil in the water Is it good to put head gasket repair to fix it. My car dose not over heat at all I have flushed the radiator but the beige or brown milky stuff keeps coming back. So should I just put the block seal in to see if that will work. The name of the stuff I am going to put in is Bar's leaks head gasket repair
Thank you
Oct 9, 2008 at 7:34 AM
85CAMAROJR
  • 5 POSTS
that head gasket may be your problem. i would put a new one in soon before it causes some major problems.
Oct 9, 2008 at 5:37 PM
