1999 Chevy Camaro My chevy is shutting of itself
1999 CHEVROLET CAMARO
ANGEL03
1999 Chevy Camaro 6 cyl Two Wheel Drive 100.00 miles
What happen is that my camaro is shutting itself in the middle of the street when the rpm are going down , when I'm approching to a stop or trafficc light or when I'm in rush traficc hours etc , It does start again inmediatly when I turn the engine again .first the check engine like code showed a bad oxigen sensor , I changed it , the light went off but the problem is still there , I'm desesperated cause I can cause an accident
Oct 10, 2008 at 8:51 AM
Check the idle air control valve/throttle position sensor/MAF/MAP sensor to include the PCV and EGR valves.
Oct 10, 2008 at 8:53 AM
