There is oil in the water but the car dos not over heat at all
Oct 9, 2008 at 5:54 AM
DOCFIXIT
✓Experienced Mechanic
Is it of a red/ brownish tint? If so check trany fluid if low there is a leak in cooling tank inside radiator
Oct 9, 2008 at 7:05 AM
ANITAW45
MEMBER
Hi It is a brownish milky color
Oct 9, 2008 at 8:29 AM
DOCFIXIT
That's more like antifreeze so there is likely a head gasket problem or small crack in cylinder valve seat.
Oct 9, 2008 at 8:38 AM
