1999 Chevy Camaro Engine swap
1999 CHEVROLET CAMARO
HISNASCAR
Engine Mechanical problem
1999 Chevy Camaro 6 cyl Two Wheel Drive Automatic 109.00 miles
When swappomg out engine on 99 camaro 3.8 v-6 from the bottom of car what all is needed to be removed for the front suspenison n motoe cradle to be free from car? thanx
Aug 31, 2010 at 6:30 PM
HMAC300
  • 48,601 POSTS
normally the engine/trans and cradle are dropped as an assembly then the engine is removed. So you hve to disconnect everything , then remove the 4 bolts that hold the cradle in and fack the car away from it.
Sep 11, 2010 at 8:28 AM
