1999 Chevy Camaro Car Bogs down.
103,000 MILES • V8 • 2WD • AUTOMATIC
PETEA00
When car has not been used for several hours or over night as you start to accelerate the car bogs down to the point where its not even moving, you can punch the acclerator to the floor board and car still will move along bogged down RPM 3000-4000 as if not getting enough gas, then all of the sudden a popping sound from the exaust or muffler and RPM nearly red lines car throws you back in your seat and takes off. Changed fuel filter but still same problem.(car is allowed to warm up prior to use)
May 27, 2008 at 1:53 AM
MUSTANG87
  • 261 POSTS
get your catalic converter checked maybe clogged .start there.even if car runs when warm can be a cat prob.
May 27, 2008 at 11:50 AM
