1999 Chevy Camaro Acceleration
138,000 MILES • 6 CYL • 2WD • MANUAL
KEROUAC420
Ive got a high mileage, 5-speed Camaro. Whenever I shift gears the car sputters for awhile (especially if Im going up hill or shifting in the higher gears). Its also very slow to accelerate and I can smell something burning. I thought it might be my clutch but I had that replaced just two years ago. I also had a tune-up recently and new water pump installed. Could it be my transmission?
Nov 4, 2010 at 7:25 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Nov 5, 2010 at 12:08 AM
