1999 Chevy Camaro 02 Sensors...how to's? PLEASE READ ME I'M
1999 CHEVROLET CAMARO
121,000 MILES • 6 CYL • 2WD • MANUAL
JDRUTHER
My camaros been running really bad! When I start it up it will either get gas or it just gets absolutely no gas at all when i step on the gas it'll either go? Or I'll have it floored & it does nothing!? Went & had a code reader on it & it came back saying alot of 02 sensor readings? Which one should I try 1st? Where are they located? What are the specs. for testing them?
Oct 17, 2009 at 9:37 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
First, I doubt the O2 sensor would cause this bad of a problem. What I need you to check first is fuel pressure.
Here is a how to for checking it:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find. Also, you will need a gauge. Most parts stores will lend or rent them to you.
Nov 1, 2009 at 12:00 PM
