1999 Chevrolet Camaro v6
YOCHRONO
1999 Camaro V6 edition with 155,000 miles. Past month or so I have had all sorts of weird things going on. The main problem is my car kept dieing and would need a jump quite often. I figured I would check the water cells in the battery which I did and they were empty so I simply filled them up. Started up fine and went about then my car wouldn't start again and needed a jump once again this time it was by a portable car charger / jumper from autozone and since then my car starts everytime. However just recently my car was just idling for under 30 seconds when it started to get a little shaky and the lights in the car were dimming in and out and what not so I just turned it off. It felt like something was about to die. Which by the way everytime I get jumped I have to reset the time and all that stuff. Also another small problem I am concerned about is sometimes when I accelerate quite quickly my car seems to hold back or feels very sluggish and or like just studder a little bit. It's like its not full on. Any help is appreciated.
Jun 28, 2007 at 2:49 PM
E40WATER12
  • 522 POSTS
Sounds like youre alternator has packed it in, Needs replacing, Also I would get the battery tested as well, Cause youre battery is very important to have a full charger, Cause it controls all the functions of youre cars sensors. If its not at full charge cause youre to crap out.
Good Luck.
Jun 28, 2007 at 9:48 PM
