1998 Chevy Camaro What could possibley be the problem?
94,000 MILES • V8 • 2WD • AUTOMATIC
KINGOFSOULGLO
I just recently had to replace a battery in my camaro today. About a week before I noticed that the power windows and m stereo would shut off for 5-10 min periods of time or switch off and on. My left turn signal no longer blinks and my right is starting to
blink slowly along with my power windows not rolling up as fast as they use to. The battery I just recently replaced does not reach the 13 amps that it should at all and it's the correct size and voltage and is brand new. Please help I have no
clue how to fix this problem
May 20, 2010 at 12:30 PM
HMAC300
  • 48,601 POSTS
your battery can be new butyour positive cable may be not to good or a bad connection. Clean the cables and check to see if you have good power going to your fuse panel with a VOM
May 21, 2010 at 3:46 AM
