1998 Chevy Camaro Total loss of gears
1998 CHEVROLET CAMARO
PANTHER35
Transmission problem
1998 Chevy Camaro 6 cyl Front Wheel Drive Manual
I was able to go into reverse, first, second and third gear. But when i went from first to second a clunking or rattling noise started from under the car. It got louder when i shifted into third. I pulled over to see if something was dragging under my car, there wasnt anything. So i pressed in clutch and shifted into first gear but the car wouldnt move, the noise just got louder. I tried all other gears but the same thing happened. What should i be looking for to see what may of happned?
Nov 16, 2008 at 10:44 PM
DOCFIXIT
  • 18,828 POSTS
Little doubt but internal trans damage. Sounds like an input bearing or the lay shaft.Won't know till it is torn down.
Nov 18, 2008 at 1:55 AM
