1998 Chevy Camaro Runs rough
1998 CHEVROLET CAMARO
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARJUMPER
Runs fine at idel or above 50 miles an hour, but between, when you accelerate car misses, runs rough, and lacks power.
Already had it tuned up, and mechanic looked it over but problem still exist.
I'm thinking maybe it is the idel aire control? I have some other ideas too, but what would you recomened the most likely problems it could be?
Thanks.
Jun 3, 2008 at 3:09 PM
BLACKOP555
  • 10,386 POSTS
since it happens in the same area i would check the MAF sensor, and also i would check the TPS, make sure it slowly changes voltage, not erratic when oppening the throttle.
could be a vaccum leak also.
Jun 4, 2008 at 1:14 AM
