1998 Chevy Camaro Occassional leaking
94,000 MILES • 6 CYL • 2WD • MANUAL
NIPE87
I recently got my coolant system flushed after noticing that someone or something poured about a quart of oil into my radiator. Prior to the flush, I was having the dial on the temperature gauage going from the middle of the gauge to the far right; only occassionally getting far enough for the fan to kick on. I would check the oil levels and they were good if not slightly over, but my radiator did not seem to be holding water/coolant. I replaced the radiator cap because we determined that it was loose and was allowing fluid to come up through there, and that seemed to help temporarily but then after repeatedly checking, the levels were still low very shortly after it was filled. I have not seen any leaks coming from the radiator itself, however over the last 24 hours, there have been two times where I would park my car (both on and off), and would come back shortly after to notice a small puddle of what looks like my antifreeze located on the ground under the front of my motor. I have no idea where this leak could be coming from because time after time of checking for them, nothing seems to be leaking. Also, since the flush, I've driven the car a good amount of distance and haven't noticed any problems with the way it runs.
Oct 14, 2009 at 1:40 AM
RACEFAN966
  • 5,029 POSTS
Ok I would have a radiator pressure test done. This is where you put a pump on the radiator inplace of the radiator cap and you pump to about 16 psi (no more) and you look for leaks. The reason I recomend doing this is because you do this with out it running and you can do this when it is cold so you can really look around and check for the leak. I would look over the bypass hose between the water pump and intake manifold and the water pump itself. See the water pump has a small hole just behind the pulley and this is a weap hole. When the inner seal on the pump goes bad it will leak out of this hole, and not always will it leak alot. Let me know what you find.
Oct 14, 2009 at 3:09 AM
