1998 Chevy Camaro leak
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROGERK55
I have a slow coolant leak that appears to be coming from the hamonic balancer on the lower, center front of the engine V6 3800. I cannot find the source, is it possible a worn seal on the balancer would allow coolant to leak?
Oct 17, 2009 at 9:45 AM
  • 110,248 POSTS
If it is on the balancer, 99% chance the water pump is leaking and it's running down onto the harmonic balancer. The balancer has nothing to do with coolant.
Under the water pump, there is a weep hole that coolant will leak from if the pump bearing or seal is bad. Check there for evidence of a leak.
Let me know what you find.
Nov 1, 2009 at 3:53 AM
