1998 Chevy Camaro knock sensor
56,000 MILES • V8 • 2WD • AUTOMATIC
JIM PICKRAL
where is the knock sensor located and how much should I expect to pay to have repaired? Also will failure of this part keep engine from starting? Thanx.
Oct 23, 2008 at 5:19 AM
  • 75,988 POSTS
Hi jim pickral and welcome to 2carpros
The knock sensor's job is to retard the ignition timing if it senses spark knock/detonation-it will not prevent the engine from starting-You might have to double check again. Did you run a DTC check and came up with the KS?
Oct 23, 2008 at 5:28 AM
