1998 Chevy Camaro exhaust rattles
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
COREY_82807
My exhaust is rattling around the right side in between the cat and the headers. But i just replaced the cat not even two months ago because i thought that was the problem and its a distinctive rattle kind of like a clanking rattle.
Jan 22, 2009 at 11:08 AM
PEAR69
  • 1,482 POSTS
Look at where the exhaust manifolds bolt up to the flaired pipes before the cat. The cat. should be replaced as a unit. The unit I am talking about has the catalytic converter and the two pipes I am talking about attached -- these pipes have flaired inlets that bolt up to the manifold (or header) with three bolts and springs. This is the manifold flange. The springs keep high tension applyed to the flange and keep this connection ridgid but flexable. These bolts should not be over tightened -- and sometimes , when you mess with the exhaust the springs can break - or the bolts themself can break.
Look at this area, it sounds to me that either a spring broke or the flange was overtightened and may have failed. keep us posted
Jan 22, 2009 at 11:47 AM
