1998 Chevy Camaro defroster will not turn off/Low coolant
NBEAVERS
Air Conditioning problem/Low coolant light
1998 Chevy Camaro V8 Manual 70,000 miles
Hi, I am just about to buy this car when a couple things happened, I had the AC on and then turned the knob to defrost. Now it will not turn off or change back to AC. The knob is turning but not the aire direction?
One other thing, the coolant low- light is stuck on. All fluids have been checked and verified to be at the full line so I m not sure why the light is still on. I checked coolant (reservoir and radiator), brake fluid, clutch, power steering...etc. Help
Aug 17, 2010 at 6:04 AM
WRENCHTECH
  • 20,760 POSTS
The low coolant light is probably due to a faulty low coolant sensor. They fail pretty often.
The mode door control I believe is operated by an electric actuator. The door may be sticking or the actuator may be bad.
Aug 17, 2010 at 6:24 AM
